Backlinks. Is it possible?
Hello!
Is there a method of getting the reverse output of a UserTable.lookupRecords().
i.e. a function to return the models and records to which the calling record it linked?
Would you please have a sample to illustrate what you intend to get?
unfortunately, Its a concept which I have not seen in grist, meaning that i am not in a position to build an example.
The idea is, if a record R, in table T, is referenced by X amount of tables. The ability to run a query to find all references to T.R
apologies in advance, if my explanation is lacking. I will try again if it is not clear.
I’m not sure I understand exactly what you mean. If you intend to get all references to “this record” in a table, it’s easy thanks to lookupRecords and CONTAINS. If you intend to get all references from any table, I don’t think it’s possible. Sample here to serve as a basis for discussion.
Yes, The intention is to get all references from any table.
This allows uses to create an arbitrary number of tables with their own schema. But a core table can pull on those User defined tables.
I think the only solution for that would be a custom widget.
Yes that’s a good idea.
Though is there a function which can find a list of tables in grist?
or would i need some sqlite level fiddling?
There is such a function in the Plugin API doc.
