I was using Ctrl-F to search for a keyword. After entering the keyword and pressing Enter, I got an error message in the bottom right hand corner. Is my search broken?
Does this happen every time? Does the page have many widgets? Are the widgets linked? We have found a problem when some widgets are linked using lists (choice lists or reference lists).
A workaround you could try, if this is on a page with some kind of linking that search is having trouble with, is to make a separate page showing the same table(s) and search on that. I realize that isn’t a great alternative.
