Grist Document Disappeared?
Attached is a screenshot when I open my Grist database url.
I simply do not see my team’s grist database. Typically I have a bookmarked URL, but clicking this simply brings me to a white page and the tab saying “Loading… - Grist” (shown in screenshot). Loading up Grist the website, then navigating to my profile, I don’t see the database there either (typically under “Recent”).
The database is on my coworker’s profile but they are unable to access the database too.
Thanks in advance for any advice.
Hi @William_Olichney, I think that would be a question for the hosts of that installation of Grist. Looks to be sail dot codes, perhaps some part of BU?
If no-one there can help you, you could try looking for any diagnostic information in your browser. For example, by opening the developer console and looking for any errors.
Thanks I’ll ask them!
Thanks for the quick response! I’m in communication with the host of the Grist document (SAIL), but I thought I would share the error from the dev console here as well.
Something is up with just loading the website. It looks like even the page you are on is garbled somehow. If I were on your computer I’d click on the “Uncaught SyntaxError” to see what is up there - the other problems are harder to learn about locally.
