Lookup using multiple conditions - checkbox and list involved
I am looking to create a lookup that works on two separate conditions within the lookup table. I have it working for the 1 but I can’t figure out how to get the syntax right for adding that 2nd lookup. I need to add in a filter that removes the item from the lookup if the checkbox is checked.
I have
LEN(Seed_Packet_Entry_Widget.lookupRecords(Varieties=$id).Seed_Packet_Name)
and need to make sure this field is unchecked. Also in Seed_Packet_Entry_Widget table. $Packet_Dead_empty_gone_whatever_
I am sure it is easy but I am struggling.
Hi @Lilly_Jane ,
To confirm, the $Packet_Dead_empty_gone_whatever_ column is a toggle type column, correct?
If you only want to include items in the lookup where this checkbox is not checked, then we can use the condition Packet_Dead_empty_gone_whatever_column==False. False means not checked and True would be for checked values. You can add this into your existing lookup like so;
LEN(Seed_Packet_Entry_Widget.lookupRecords(Varieties=$id, Packet_Dead_empty_gone_whatever_column==False).Seed_Packet_Name)
Let me know if you have any follow up questions!
