Hi folks! I’m still struggling with simple relations… Sorry about this.
I have a TABLE A with the following columns:
thing
I have a TABLE B with the following columns
thing (referenced to TABLE A-thing)
partOfThing (agregating from TABLE B)
Then, I want to show in TABLE A a new column with a list of parts of each thing
Example:
TABLE A
thing | partOfThing (from TABLE B)
car | wheel, engine
TABLE B
thing | partOfThing
car | wheel
car | engine
Is it clear?
Is there a general rule/template for this?
Take a look at References and Lookups - Grist Help Center. It has a very similar example.
In your case, I would do two things:
- Ensure that column
thing
in TABLE B is of type Reference to TABLE A.
- Set the formula for column
partsOfThing
in TABLE A to:TABLE_B.lookupRecords(thing=$id)
It would collect all records in TABLE B whose thing
column points to the current record of TABLE A. It returns an actual list of records. To see the name of the part from those records, you could set the column type to a ReferenceList, or you could keep it as text, and operate on it further with a formula, e.g. join with a newline to have a multi-line cell with one part per line:
"\n".join(r.partOfThing for r in TABLE_B.lookupRecords(thing=$id))
Thanks Dimitry!
I got the first part, and works fine. I’ll be back to second part asap.
