Selecting/autofilling multiple columns
If I select a table from another table, such as Interactions of a Contact, and enter a new interaction, it automatically fills in the Contact. However, I also want to display all interactions related to a specific Project column in the Interactions table. Is there a way to make it automatically fill in the Project with the Project I’m currently limiting the view to, in addition to the selected Contact? I’m currently using a filter to limit the table to the specific project as I don’t know another way to display a table that’s limited to both the selected Contact and a particular Project.
Thank you.
