Hello all! I am currently setting up Grist on n8n. This is probably a super easy question - In the setup, it asks for the Grist Document ID and the Table ID. Where can I find these?
For the Document ID: Creating a document - Grist Help Center
The Table ID is the name of the table as used in formulas, with some characters like spaces replaced by underscores. If you’re not sure exactly what it is you can try finding it in the Code View or start to type the name in a formula and look at the autocomplete.
