Hello, i am using a self-hosted (non-enterprise) grist with cloud storage on a Minio
I did read the following about the topic at hand
- Cloud storage - Grist Help Center
- the
shouldKeepSnapshots()function inDocSnapshots.ts - the
/api/docs/:docId/snapshots/removeroute unDocApi.ts
As i understand from to the documentation, GRIST_SNAPSHOT_TIME_CAP defines “a maximum number of backups to keep for each time period” and GRIST_SNAPSHOT_KEEP overrides the minimum (total ?) number of revisions to keep (over all time periods ?). The default value for hours is 25, and for days it is 30, and keep is 5.
And as of now (2025-11-19T13:02:11UTC) i have these revisions for one of my document
newer, snapshot suppression possibly not triggered yet
M “lastModified”: "2025-11-19T10:32:32.702Z
L “lastModified”: "2025-11-19T10:30:18.444Z
K “lastModified”: "2025-11-19T10:28:22.814Z
J “lastModified”: "2025-11-19T10:22:42.433Z
H “lastModified”: "2025-11-19T10:06:20.072Z
kept as last from the hour and less than 25 hours
G “lastModified”: "2025-11-19T09:21:39.729Z
kept as last from the hour and last for day
F “lastModified”: "2025-11-18T09:36:00.888Z
B “lastModified”: "2025-11-17T16:00:21.800Z
kept as last from the hour, not last of day, but more than 25 hours ago
A “lastModified”: "2025-11-17T15:40:14.957Z
This morning i had these versions for the same document
G “lastModified”: “2025-11-19T09:21:39.729Z”
F “lastModified”: “2025-11-18T09:36:00.888Z”
E “lastModified”: “2025-11-18T09:35:47.857Z” → auto-removed since
D “lastModified”: “2025-11-18T09:35:22.966Z” → auto-removed since
C “lastModified”: “2025-11-18T09:34:49.952Z” → auto-removed since
B “lastModified”: “2025-11-17T16:00:21.800Z”
A “lastModified”: “2025-11-17T15:40:14.957Z”
As i have/had more than KEEP (5) versions, i think some should have be deleted anyway, which happened and is great, but i think some were either missed, or it is working as intended and i do not understand why they were kept.
So here are a few questions :
candidates for deletion
- B is more than 25 hours ago but was the last of its day, so has been kept. correct ?
- as stated above, i feel that A should have been removed, but was not. Working as intended ?
snapshot deletion process
- when are the snapshot remove triggered ?
- what triggers it ?
- are all documents evaluated ?
- is there any additional setup required (cron job, config ?)
- mainly, how can i ensure i “globally” trim down storage" ?
Does the KEEP parameter work across all time periods or for each time period ?
As always with storage, i am worrying about creeping capacity costs for when i open service to users.
Thanks in advance for any help
Nicolas
