Access Rules for Content Creation Project Management
I am looking to create project management workflow for content team (writers & editors).
I have a scenario where, when the Writer updates the “Status” of row as “Written”, the row gets assigned to an Editor and isn’t visible to the Writer.
Each Writer will be pre-assigned with an Editor.
Let me know if this is possible with GetGrist?
Sure, it’s possible. It should event be fairly easy, with references, autorship columns and access rules.
Will try to apply this. Can it be done without authorship column? A table where I will add user email which will act as author and access rules are applied in it.
There are other means I might think about, but they all seem far more complicated to me. If the point is hiding authorship information from others, you could restrict access to it in access rules.
