Adjusting pin color in maps widget
Really liking the map widget. It’s ability to visualize location really helps.
But now that I’m visualizing multiple different categories of locations on the same map, I’m really missing the ability to adjust the color of individual pins. I’ve tried finding a way, but I was unable to.
The suggestion is for the map widget to accept an additional, optional column, that would provide either HTML color codes, 8bit RGB color values as integers, or plain text color names, that would then reflect on the color of the pin.
I haven’t yet found any other request for this feature, but it seems to me like a fairly basic and important feature to enable more complex data visualization.
