Advnaced filter options
Hello
I have searched and been unable to find the answer
Is it possible to filter using two or more columns, but so it is “or” and not “and”, or a mixture of both
I’m making comic database. I want to be able to filter to inculde books from certain lines OR any specific charcter. For example, any x-men related book or any book that has wolverine.
Currently as far i can see or work, the filters would display only x-men related books that also had woverine in them
Thanks in advance
No, as for now, it’s always or for the same column, and for different columns. You could find a workaround here.
I workaround would be add a column that calculates True or False based on the criteria you want, then filter by that column.
Thanks for the responses, but it needs to be user friendly, not coder friendly :pensive:
