AI assistant and Ollama
Hello.
Ollama is installed on my computer, on Linux Ubuntu.
I’m running Grist with this command :
docker run -p 8484:8484  \
--network host \
-e ASSISTANT_CHAT_COMPLETION_ENDPOINT=http://localhost:11434/api/generate   \
-e ASSISTANT_MODEL=llama2   \
-e ASSISTANT_API_KEY=   \
-v $PWD/GRIST_persist:/persist   -it gristlabs/grist
But, unfortunately, the AI Formulas Assistant seems not to run correctly. :sleepy:
This is the result in the log :
 warn: Waiting and then retrying after error: TypeError: Cannot read properties of undefined (reading '0')
2025-04-10 09:09:51.022 - warn: Error during api call to /docs/nJ4nxPEEeKUYn1fX8dyfUN/assistant: Sorry, the assistant is unavailable right now. Try again in a few minutes.
(TypeError: Cannot read properties of undefined (reading '0')) path=/docs/nJ4nxPEEeKUYn1fX8dyfUN/assistant, userId=5, altSessionId=nGrRun1rrHUXP6f9kj6azt, conversationId=f37cae7b-b5c1-472d-962a-3e79ac5baad9, type=formula, tableId=Table1, colId=A, text=Concaténer ID2 et nom_demarche,
Is there someone with the same problem ?
Is someone OK with this config ?
Could you help me ?
Thanks.
Hi @Luc_Leger, does the model have /api/v1/chat/completions available? That’s the kind of OpenAI-compatible conversational endpoint Grist needs.
Yes ! It’s run nicely ! :slightly_smiling_face: :+1:
Big thanks to you @paul-grist
So, the definitive command is :
  --network host \
  -e ASSISTANT_CHAT_COMPLETION_ENDPOINT=http://localhost:11434/v1/chat/completions   \
It’s run also with LLM Mistral :wink: :fr:
Hi @Luc_Leger,
thanks a lot for sharing your Ollama setup and the working command with /v1/chat/completions – very helpful!
I have a quick question: in your case, was this only the AI Formula Assistant that you got working, or did you also manage to run the full AI Assistant (Enterprise self‑hosted version) with a local Ollama model?
I’m currently evaluating Grist Enterprise self‑hosted with local models and would love to know if you’ve successfully used the full Assistant in this configuration.
Thanks in advance for any details you can share!
