Hey,
Why I cannot see, the picture field (attachment), in the list
when I am adding a widget for “Image viewer” ?
I added the rows from the API , i dunno if it matters ?
Hi Sao,
The Image Viewer custom widget is for viewing images at certain URLs, so the only picture fields that can be read are text fields that contain URLs. To view images that are stored as attachments, maybe try using a card widget that only displays the attachment field? You can then set the thumbnail size for that column/field to the largest size possible. Won’t be as big as in the image viewer, unfortunately
Aaah oki thanks .
Yeah unfortunately, like you said, with the card view, it’s quite small too.
