Hello, Grist team.
Is possible to create Automatic Export .grist project by timer or by event as .sqlite/.xls/.cvs?
May be by n8n?
If i use external Report Generator, every time need manualy export project for generating report.
May be is possible automate this task.
Or another example if use .grist project as DB for dynamyc website, the same problem.
I’m interesting about a Report Generator… What do you use for it.
For instance I’m actually n8n with cron module to export doc as json but you can dot it the way you want.
Hello @Sylvain_Page I use FastReport Desktop.
I am new to n8n just installed yesterday.
