AWS S3 bucket & snapshots not working
Setup Grist from AWS Marketplace. I have instance and S3 bucket in place. Website works fine, but S3 bucket is not working with instance and I am not sure what the issue is. What is the variable(s) to enable S3 bucket? I do have versioning enabled on S3 bucket.
Contents of gristParameter file:
EMAIL=
URL=
MS_CLIENT_ID=(hidden)
MS_CLIENT_SECRET=(hidden)
STORAGE=/home/ubuntu/grist-persist
GRIST_DOCS_S3_BUCKET=gristbucket01
GRIST_DOCS_S3_PREFIX=v1/
GRIST_DOCS_S3_ENDPOINT=s3.amazonaws.com
AWS_ACCESS_KEY_ID=(hidden)
AWS_SECRET_ACCESS_KEY=(hidden)
Docker Logs:
2024-08-01 11:14:39.008 - info: == grist.access.supportEmail: support@getgrist.com [default] [GRIST_SUPPORT_EMAIL]
2024-08-01 11:14:39.008 - info: == grist.access.listPublicSites: false [default] [GRIST_LIST_PUBLIC_SITES]
2024-08-01 11:14:39.008 - info: == grist.access.installAdminEmail: [GRIST_DEFAULT_EMAIL]
2024-08-01 11:14:39.008 - info: == grist.integrations.sql.timeout: 1000 [default] [GRIST_SQL_TIMEOUT_MSEC]
2024-08-01 11:14:39.008 - info: == grist.integrations.allowedWebhookDomains: - [ALLOWED_WEBHOOK_DOMAINS]
2024-08-01 11:14:39.008 - info: == grist.integrations.proxy: - [GRIST_HTTPS_PROXY]
2024-08-01 11:14:39.008 - info: == grist.locale.offerAllLanguages: - [GRIST_OFFER_ALL_LANGUAGES]
2024-08-01 11:14:39.008 - info: == grist.login.system.forwardAuth.header: X-Forwarded-User [GRIST_FORWARD_AUTH_HEADER]
2024-08-01 11:14:39.008 - info: == grist.login.system.forwardAuth.active: true
2024-08-01 11:14:39.008 - info: == grist.login.system.forwardAuth.logoutPath: _oauth/logout [GRIST_FORWARD_AUTH_LOGOUT_PATH]
2024-08-01 11:14:39.008 - info: == grist.login.system.forwardAuth.loginPath: /auth/login [default] [GRIST_FORWARD_AUTH_LOGIN_PATH]
2024-08-01 11:14:39.008 - info: == grist.login.skipSession: - [GRIST_IGNORE_SESSION]
2024-08-01 11:14:39.008 - info: == grist.login.forced: true [GRIST_FORCE_LOGIN]
2024-08-01 11:14:39.008 - info: == grist.externalStorage.minio.bucket: - [GRIST_DOCS_MINIO_BUCKET]
2024-08-01 11:14:39.008 - info: == grist.externalStorage.disable: - [GRIST_DISABLE_S3]
2024-08-01 11:14:39.009 - info: == grist.externalStorage.active: false
Having a similar issue trying to get the snapshot to work.
The docker logs show this. What is GRIST_DISABLE_S3 ? I do not see documentation on this.
2024-08-01 11:46:02.050 - info: == grist.locale.offerAllLanguages: - [GRIST_OFFER_ALL_LANGUAGES]
2024-08-01 11:46:02.050 - info: == grist.login.system.forwardAuth.header: X-Forwarded-User [GRIST_FORWARD_AUTH_HEADER]
2024-08-01 11:46:02.050 - info: == grist.login.system.forwardAuth.active: true
2024-08-01 11:46:02.050 - info: == grist.login.system.forwardAuth.logoutPath: _oauth/logout [GRIST_FORWARD_AUTH_LOGOUT_PATH]
2024-08-01 11:46:02.050 - info: == grist.login.system.forwardAuth.loginPath: /auth/login [default] [GRIST_FORWARD_AUTH_LOGIN_PATH]
2024-08-01 11:46:02.050 - info: == grist.login.skipSession: - [GRIST_IGNORE_SESSION]
2024-08-01 11:46:02.050 - info: == grist.login.forced: true [GRIST_FORCE_LOGIN]
2024-08-01 11:46:02.050 - info: == grist.externalStorage.minio.bucket: - [GRIST_DOCS_MINIO_BUCKET]
2024-08-01 11:46:02.050 - info: == grist.externalStorage.disable: - [GRIST_DISABLE_S3]
2024-08-01 11:46:02.050 - info: == grist.externalStorage.active: false
Same for self-hosted MINIO setup
All the parameters should be MINIO for the storage? The documentation says to use GRIST_DOCS_S3_BUCKET, AWS_ACCESS_KEY_ID and AWS_SECRET_ACCESS_KEY.
