I’ve jus re-run a new session with all cookies cleared and I’ve exported the logs with DEBUG=1. Find it below.
Everything worked fine, even logging out. But I guess I should try to fix the code to work properly with Azure AD regardless
Welcome to Grist.
2022-08-04 12:13:39.024 - e[32minfoe[39m: == Grist version is 0.1.1 (commit unknown)
2022-08-04 12:13:39.031 - e[32minfoe[39m: Loading empty config because /persist/config.json missing
2022-08-04 12:13:39.038 - e[32minfoe[39m: SamlConfig set with host http://localhost:8484, IdP https://login.microsoftonline.com/<my-tenant-uuid>/saml2
2022-08-04 12:13:39.053 - e[33mwarne[39m: did not find an appropriately named example workspace in deployment
2022-08-04 12:13:39.070 - e[32minfoe[39m: No plugins directory: ENOENT: no such file or directory, scandir '/grist/.grist/plugins'
2022-08-04 12:13:39.078 - e[32minfoe[39m: Found 1 valid plugins on the system
2022-08-04 12:13:39.078 - e[34mdebuge[39m: PLUGIN builtIn/core -- /grist/plugins/core
2022-08-04 12:13:39.088 - e[32minfoe[39m: Server timeouts: keepAliveTimeout 305000 headersTimeout 306000
2022-08-04 12:13:39.094 - e[32minfoe[39m: server(home,docs,static) available at 0.0.0.0:8484
2022-08-04 12:13:39.104 - e[33mwarne[39m: Failed to create GoogleAuth endpoint: GOOGLE_CLIENT_SECRET is not defined
2022-08-04 12:13:39.110 - e[32minfoe[39m: == appRoot: /grist
2022-08-04 12:13:39.110 - e[32minfoe[39m: == docsRoot: /persist/docs
2022-08-04 12:13:39.110 - e[32minfoe[39m: == defaultBaseDomain: undefined
2022-08-04 12:13:39.110 - e[32minfoe[39m: == pluginUrl: undefined
2022-08-04 12:13:39.110 - e[32minfoe[39m: == instanceRoot: /persist
2022-08-04 12:13:39.110 - e[32minfoe[39m: == tag: unknown
2022-08-04 12:13:39.110 - e[32minfoe[39m: == database: sqlite:///persist/home.sqlite3
2022-08-04 12:13:39.111 - e[32minfoe[39m: == userRoot: /grist/.grist
2022-08-04 12:13:39.111 - e[32minfoe[39m: == loginMiddlewareComment: saml
2022-08-04 12:13:39.111 - e[32minfoe[39m: == docWorkerId: testDocWorkerId_8484
2022-08-04 12:13:39.111 - e[32minfoe[39m: == grist.login.skipSession: - [GRIST_IGNORE_SESSION]
2022-08-04 12:13:39.112 - e[32minfoe[39m: == grist.login.forced: - [GRIST_FORCE_LOGIN]
2022-08-04 12:13:39.112 - e[32minfoe[39m: == grist.externalStorage.disable: - [GRIST_DISABLE_S3]
2022-08-04 12:13:39.112 - e[32minfoe[39m: == grist.externalStorage.active: false
2022-08-04 12:13:39.119 - e[32minfoe[39m: activity docCount=0, orgCount=1, orgInGoodStandingCount=1, userCount=5, userWithLoginCount=5
2022-08-04 12:13:44.192 - e[34mdebuge[39m: Auth[GET]: localhost:8484 / customHostSession=, method=GET, host=localhost:8484, path=/, org=example, email=anon@getgrist.com, userId=1, altSessionId=tbLm3njx6rcoC8g7WdrEQ7
2022-08-04 12:13:44.203 - e[34mdebuge[39m: Authorizer: redirecting to sign up
2022-08-04 12:13:44.253 localhost:8484 GET / 302 49.686 ms - 2398
2022-08-04 12:13:49.387 - e[32minfoe[39m: SamlConfig: got SAML response for ireche@example.com (Ivan Ferrucio Reche da Silva Filgueiras) redirecting to http://localhost:8484/
2022-08-04 12:13:49.430 - e[31merrore[39m: ScopedSession[g-a8KqT3kkEKhXwotn2DbESs]: Error updating sessionStore: Error: failed to load session
2022-08-04 12:13:49.433 localhost:8484 POST /saml/assert 302 152.439 ms - 88
2022-08-04 12:13:49.455 - e[34mdebuge[39m: Auth[GET]: localhost:8484 / customHostSession=, method=GET, host=localhost:8484, path=/, org=example, email=ireche@example.com, userId=5, altSessionId=tbLm3njx6rcoC8g7WdrEQ7
2022-08-04 12:13:49.456 - e[34mdebuge[39m: welcoming user: ireche@example.com
2022-08-04 12:13:49.549 localhost:8484 GET / 200 83.658 ms - 3676
2022-08-04 12:13:49.596 localhost:8484 GET /v/unknown/jqueryui/themes/smoothness/jquery-ui.css 304 7.409 ms - -
2022-08-04 12:13:49.608 localhost:8484 GET /v/unknown/bundle.css 304 3.796 ms - -
2022-08-04 12:13:49.613 localhost:8484 GET /v/unknown/bootstrap/dist/css/bootstrap.min.css 304 5.971 ms - -
2022-08-04 12:13:49.614 localhost:8484 GET /v/unknown/hljs.default.css 304 3.294 ms - -
2022-08-04 12:13:49.626 localhost:8484 GET /v/unknown/bootstrap-datepicker/dist/css/bootstrap-datepicker3.min.css 304 6.803 ms - -
2022-08-04 12:13:49.628 localhost:8484 GET /v/unknown/icons/icons.css 304 4.581 ms - -
2022-08-04 12:13:49.629 localhost:8484 GET /v/unknown/jqueryui/jquery-ui.min.js 304 8.594 ms - -
2022-08-04 12:13:49.633 localhost:8484 GET /v/unknown/bootstrap/dist/js/bootstrap.min.js 304 10.685 ms - -
2022-08-04 12:13:49.635 localhost:8484 GET /v/unknown/bootstrap-datepicker/dist/js/bootstrap-datepicker.min.js 304 12.380 ms - -
2022-08-04 12:13:49.638 localhost:8484 GET /v/unknown/jquery/dist/jquery.min.js 304 14.158 ms - -
2022-08-04 12:13:49.640 localhost:8484 GET /v/unknown/main.bundle.js 304 2.773 ms - -
2022-08-04 12:13:49.642 localhost:8484 GET /v/unknown/browser-check.js 304 0.852 ms - -
2022-08-04 12:13:49.652 localhost:8484 GET /v/unknown/img/gplaypattern.png 304 0.660 ms - -
2022-08-04 12:13:49.950 - e[34mdebuge[39m: Auth[GET]: localhost:8484 /session/access/all customHostSession=, method=GET, host=localhost:8484, path=/session/access/all, org=example, email=ireche@example.com, userId=5, altSessionId=tbLm3njx6rcoC8g7WdrEQ7
2022-08-04 12:13:49.993 - e[34mdebuge[39m: Auth[GET]: localhost:8484 /session/access/active customHostSession=, method=GET, host=localhost:8484, path=/session/access/active, org=example, email=ireche@example.com, userId=5, altSessionId=tbLm3njx6rcoC8g7WdrEQ7
2022-08-04 12:13:50.037 localhost:8484 GET /o/example/api/session/access/all 200 52.096 ms - 734
2022-08-04 12:13:50.058 localhost:8484 GET /o/example/api/session/access/active 200 77.245 ms - 582
2022-08-04 12:13:50.101 - e[34mdebuge[39m: Auth[GET]: localhost:8484 /orgs/3/workspaces customHostSession=, method=GET, host=localhost:8484, path=/orgs/3/workspaces, org=example, email=ireche@example.com, userId=5, altSessionId=tbLm3njx6rcoC8g7WdrEQ7
2022-08-04 12:13:50.143 - e[34mdebuge[39m: Auth[GET]: localhost:8484 /orgs/3/usage customHostSession=, method=GET, host=localhost:8484, path=/orgs/3/usage, org=example, email=ireche@example.com, userId=5, altSessionId=tbLm3njx6rcoC8g7WdrEQ7
2022-08-04 12:13:50.161 - e[34mdebuge[39m: Auth[GET]: localhost:8484 /templates customHostSession=, method=GET, host=localhost:8484, path=/templates, org=example, email=ireche@example.com, userId=5, altSessionId=tbLm3njx6rcoC8g7WdrEQ7
2022-08-04 12:13:50.187 localhost:8484 GET /o/example/api/orgs/3/workspaces?includeSupport=1 200 48.552 ms - 195
2022-08-04 12:13:50.207 localhost:8484 GET /o/example/api/orgs/3/usage 304 67.946 ms - -
2022-08-04 12:13:50.229 localhost:8484 GET /o/example/api/templates?onlyFeatured=1 404 101.385 ms - 34
2022-08-04 12:13:54.577 - e[34mdebuge[39m: Auth[GET]: localhost:8484 /orgs/3/workspaces customHostSession=, method=GET, host=localhost:8484, path=/orgs/3/workspaces, org=example, email=ireche@example.com, userId=5, altSessionId=tbLm3njx6rcoC8g7WdrEQ7
2022-08-04 12:13:54.657 localhost:8484 GET /o/example/api/orgs/3/workspaces?includeSupport=1 304 38.297 ms - -
2022-08-04 12:13:57.682 - e[34mdebuge[39m: Auth[POST]: localhost:8484 /workspaces/3/docs customHostSession=, method=POST, host=localhost:8484, path=/workspaces/3/docs, org=example, email=ireche@example.com, userId=5, altSessionId=tbLm3njx6rcoC8g7WdrEQ7
2022-08-04 12:13:57.804 localhost:8484 POST /o/example/api/workspaces/3/docs 200 101.985 ms - 24
2022-08-04 12:13:57.824 - e[34mdebuge[39m: Auth[GET]: localhost:8484 /orgs/3/workspaces customHostSession=, method=GET, host=localhost:8484, path=/orgs/3/workspaces, org=example, email=ireche@example.com, userId=5, altSessionId=tbLm3njx6rcoC8g7WdrEQ7
2022-08-04 12:13:57.860 localhost:8484 GET /o/example/api/orgs/3/workspaces?includeSupport=1 200 31.976 ms - 389
2022-08-04 12:13:57.875 - e[34mdebuge[39m: Auth[GET]: localhost:8484 /docs/cmPEpwBuq4RWL9jwCuN4tx customHostSession=, method=GET, host=localhost:8484, path=/docs/cmPEpwBuq4RWL9jwCuN4tx, org=example, email=ireche@example.com, userId=5, altSessionId=tbLm3njx6rcoC8g7WdrEQ7
2022-08-04 12:13:57.899 localhost:8484 GET /o/example/api/docs/cmPEpwBuq4RWL9jwCuN4tx 200 16.620 ms - 868
2022-08-04 12:13:57.988 - e[34mdebuge[39m: Auth[GET]: localhost:8484 /cmPEpwBuq4RW/Untitled-document customHostSession=, method=GET, host=localhost:8484, path=/cmPEpwBuq4RW/Untitled-document, org=example, email=ireche@example.com, userId=5, altSessionId=tbLm3njx6rcoC8g7WdrEQ7
2022-08-04 12:13:58.019 localhost:8484 GET /cmPEpwBuq4RW/Untitled-document 200 27.666 ms - 4672
2022-08-04 12:13:58.039 localhost:8484 GET /v/unknown/jqueryui/themes/smoothness/jquery-ui.css 304 1.041 ms - -
2022-08-04 12:13:58.044 localhost:8484 GET /v/unknown/hljs.default.css 304 1.628 ms - -
2022-08-04 12:13:58.046 localhost:8484 GET /v/unknown/bootstrap/dist/css/bootstrap.min.css 304 4.629 ms - -
2022-08-04 12:13:58.046 localhost:8484 GET /v/unknown/bootstrap-datepicker/dist/css/bootstrap-datepicker3.min.css 304 3.606 ms - -
2022-08-04 12:13:58.047 localhost:8484 GET /v/unknown/bundle.css 304 2.371 ms - -
2022-08-04 12:13:58.049 localhost:8484 GET /v/unknown/icons/icons.css 304 3.701 ms - -
2022-08-04 12:13:58.053 localhost:8484 GET /v/unknown/jquery/dist/jquery.min.js 304 4.384 ms - -
2022-08-04 12:13:58.066 localhost:8484 GET /v/unknown/jqueryui/jquery-ui.min.js 304 5.618 ms - -
2022-08-04 12:13:58.067 localhost:8484 GET /v/unknown/bootstrap/dist/js/bootstrap.min.js 304 5.866 ms - -
2022-08-04 12:13:58.068 localhost:8484 GET /v/unknown/main.bundle.js 304 3.677 ms - -
2022-08-04 12:13:58.069 localhost:8484 GET /v/unknown/browser-check.js 304 3.683 ms - -
2022-08-04 12:13:58.069 localhost:8484 GET /v/unknown/bootstrap-datepicker/dist/js/bootstrap-datepicker.min.js 304 7.542 ms - -
2022-08-04 12:13:58.218 - e[34mdebuge[39m: Auth[GET]: localhost:8484 /session/access/all customHostSession=, method=GET, host=localhost:8484, path=/session/access/all, org=example, email=ireche@example.com, userId=5, altSessionId=tbLm3njx6rcoC8g7WdrEQ7
2022-08-04 12:13:58.243 - e[34mdebuge[39m: Auth[GET]: localhost:8484 /session/access/active customHostSession=, method=GET, host=localhost:8484, path=/session/access/active, org=example, email=ireche@example.com, userId=5, altSessionId=tbLm3njx6rcoC8g7WdrEQ7
2022-08-04 12:13:58.260 - e[34mdebuge[39m: Auth[GET]: localhost:8484 /worker/cmPEpwBuq4RWL9jwCuN4tx customHostSession=, method=GET, host=localhost:8484, path=/worker/cmPEpwBuq4RWL9jwCuN4tx, org=example, email=ireche@example.com, userId=5, altSessionId=tbLm3njx6rcoC8g7WdrEQ7
2022-08-04 12:13:58.266 localhost:8484 GET /o/example/api/session/access/all 304 32.643 ms - -
2022-08-04 12:13:58.304 localhost:8484 GET /o/example/api/worker/cmPEpwBuq4RWL9jwCuN4tx 200 31.365 ms - 55
2022-08-04 12:13:58.305 localhost:8484 GET /o/example/api/session/access/active 304 54.241 ms - -
2022-08-04 12:13:58.307 localhost:8484 GET /v/unknown/652.bundle.js 304 0.820 ms - -
2022-08-04 12:13:58.342 localhost:8484 GET /v/unknown/684.bundle.js 304 4.151 ms - -
2022-08-04 12:13:58.344 localhost:8484 GET /v/unknown/119.bundle.js 304 4.118 ms - -
2022-08-04 12:13:58.345 localhost:8484 GET /v/unknown/931.bundle.js 304 4.455 ms - -
2022-08-04 12:13:58.346 localhost:8484 GET /v/unknown/741.bundle.js 304 4.535 ms - -
2022-08-04 12:13:58.361 localhost:8484 GET /v/unknown/420.bundle.js 304 2.788 ms - -
2022-08-04 12:13:58.361 - e[34mdebuge[39m: Auth[GET]: localhost:8484 /docs/cmPEpwBuq4RW customHostSession=, method=GET, host=localhost:8484, path=/docs/cmPEpwBuq4RW, org=example, email=ireche@example.com, userId=5, altSessionId=tbLm3njx6rcoC8g7WdrEQ7
2022-08-04 12:13:58.416 localhost:8484 GET /o/example/api/docs/cmPEpwBuq4RW 200 46.540 ms - 868
2022-08-04 12:13:58.429 - e[32minfoe[39m: Comm: Got Websocket connection clientId=7878f899a0381381, counter=null, urlPath=/?clientId=0&counter=1&newClient=1&browserSettings=%7B%22timezone%22%3A%22America%2FSao_Paulo%22%7D&user=ireche%40example.com, reuseClient=false
2022-08-04 12:13:58.432 - e[34mdebuge[39m: Client sending clientConnect newClient=true, needReload=false, docsClosed=0, missedMessages=undefined, email=ireche@example.com, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1
2022-08-04 12:13:58.446 - e[32minfoe[39m: Client onMessage '{"reqId":0,"method":"openDoc","args":["cmPEpwBuq4RWL9jwCuN4tx","default",null]}' email=ireche@example.com, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1
2022-08-04 12:13:58.452 - e[34mdebuge[39m: DocManager.openDoc Authorizer key { urlId: 'cmPEpwBuq4RWL9jwCuN4tx', userId: 5, org: 'example' }
2022-08-04 12:13:58.453 - e[34mdebuge[39m: DocManager.fetchDoc cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:58.482 - e[34mdebuge[39m: ActiveDoc loadDoc access=owners, userId=5, email=ireche@example.com, age=0, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1, docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:58.486 - e[34mdebuge[39m: ActiveDoc createDoc access=owners, userId=5, email=ireche@example.com, age=0, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1, docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:58.513 - e[34mdebuge[39m: DB cmPEpwBuq4RWL9jwCuN4tx open successfully
2022-08-04 12:13:58.527 - e[34mdebuge[39m: ActiveDoc Loading 21 normal tables, skipping 0 on-demand tables access=owners, userId=5, email=ireche@example.com, age=0, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1, docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:58.528 - e[34mdebuge[39m: ActiveDoc Normal tables: Table1, _grist_ACLMemberships, _grist_ACLPrincipals, _grist_ACLResources, _grist_ACLRules, _grist_Attachments, _grist_DocInfo, _grist_External_database, _grist_External_table, _grist_Filters, _grist_Imports, _grist_Pages, _grist_REPL_Hist, _grist_TabBar, _grist_TabItems, _grist_TableViews, _grist_Triggers, _grist_Validations, _grist_Views, _grist_Views_section, _grist_Views_section_field access=owners, userId=5, email=ireche@example.com, age=0, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1, docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:58.529 - e[34mdebuge[39m: ActiveDoc On-demand tables: access=owners, userId=5, email=ireche@example.com, age=0, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1, docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:58.530 - e[34mdebuge[39m: ActiveDoc starting to load 20 tables: _grist_ACLMemberships, _grist_ACLPrincipals, _grist_ACLResources, _grist_ACLRules, _grist_Attachments, _grist_DocInfo, _grist_External_database, _grist_External_table, _grist_Filters, _grist_Imports, _grist_Pages, _grist_REPL_Hist, _grist_TabBar, _grist_TabItems, _grist_TableViews, _grist_Triggers, _grist_Validations, _grist_Views, _grist_Views_section, _grist_Views_section_field access=owners, userId=5, email=ireche@example.com, age=0, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1, docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:58.573 - e[34mdebuge[39m: 3-pipe Sandbox started sandboxPid=21, flavor=unsandboxed, command=undefined, entryPoint=(default), docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:58.591 - e[34mdebuge[39m: DocClients now 1 clients; new client is 7878f899a0381381 (fd 0) access=owners, userId=5, email=ireche@example.com, age=0, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1, docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:58.592 - e[32minfoe[39m: ActiveDoc will stay open access=owners, userId=5, email=ireche@example.com, age=0, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1, docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:58.592 - e[32minfoe[39m: ActiveDoc fetchMetaTables access=owners, userId=5, email=ireche@example.com, age=0, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1, docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:58.601 - e[34mdebuge[39m: Time taken in getRecentMinimalActionGroups: 1 ms
2022-08-04 12:13:58.674 - e[32minfoe[39m: Client onMessage '{"reqId":1,"method":"fetchTable","args":[0,"Table1"]}' email=ireche@example.com, userId=5, age=0, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1
2022-08-04 12:13:58.675 - e[34mdebuge[39m: activeDocMethod access=owners, userId=5, email=ireche@example.com, age=0, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1, docId=cmPEpwBuq4RWL9jwCuN4tx, docMethod=fetchTable
2022-08-04 12:13:58.677 - e[32minfoe[39m: ActiveDoc fetchQuery {"tableId":"Table1","filters":{}} (regular) access=owners, userId=5, email=ireche@example.com, age=0, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1, docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:58.680 - e[32minfoe[39m: ActiveDoc fetchQuery -> 0 rows, cols: manualSort, A, B, C access=owners, userId=5, email=ireche@example.com, age=0, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1, docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:58.814 localhost:8484 GET /v/unknown/bootstrap/dist/fonts/glyphicons-halflings-regular.woff2 304 1.827 ms - -
2022-08-04 12:13:59.780 - e[32minfoe[39m: Sandbox stderr: [INFO] [__main__] Ready sandboxPid=21, flavor=unsandboxed, command=undefined, entryPoint=(default), docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:59.796 - e[34mdebuge[39m: Sandbox pyCall[load_meta_tables] took 1222 ms sandboxPid=21, flavor=unsandboxed, command=undefined, entryPoint=(default), docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:59.797 - e[34mdebuge[39m: Sandbox pyCall[load_table] took 1 ms sandboxPid=21, flavor=unsandboxed, command=undefined, entryPoint=(default), docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:59.798 - e[34mdebuge[39m: Sandbox pyCall[load_table] took 1 ms sandboxPid=21, flavor=unsandboxed, command=undefined, entryPoint=(default), docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:59.799 - e[34mdebuge[39m: Sandbox pyCall[load_table] took 2 ms sandboxPid=21, flavor=unsandboxed, command=undefined, entryPoint=(default), docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:59.799 - e[34mdebuge[39m: Sandbox pyCall[load_table] took 1 ms sandboxPid=21, flavor=unsandboxed, command=undefined, entryPoint=(default), docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:59.800 - e[34mdebuge[39m: Sandbox pyCall[load_table] took 2 ms sandboxPid=21, flavor=unsandboxed, command=undefined, entryPoint=(default), docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:59.800 - e[34mdebuge[39m: Sandbox pyCall[load_table] took 1 ms sandboxPid=21, flavor=unsandboxed, command=undefined, entryPoint=(default), docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:59.800 - e[34mdebuge[39m: Sandbox pyCall[load_table] took 0 ms sandboxPid=21, flavor=unsandboxed, command=undefined, entryPoint=(default), docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:59.801 - e[34mdebuge[39m: Sandbox pyCall[load_table] took 1 ms sandboxPid=21, flavor=unsandboxed, command=undefined, entryPoint=(default), docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:59.802 - e[34mdebuge[39m: Sandbox pyCall[load_table] took 1 ms sandboxPid=21, flavor=unsandboxed, command=undefined, entryPoint=(default), docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:59.803 - e[34mdebuge[39m: Sandbox pyCall[load_table] took 2 ms sandboxPid=21, flavor=unsandboxed, command=undefined, entryPoint=(default), docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:59.803 - e[34mdebuge[39m: Sandbox pyCall[load_table] took 1 ms sandboxPid=21, flavor=unsandboxed, command=undefined, entryPoint=(default), docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:59.804 - e[34mdebuge[39m: ActiveDoc loading 1 tables: Table1 access=owners, userId=5, email=ireche@example.com, age=0, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1, docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:59.806 - e[34mdebuge[39m: Sandbox pyCall[load_table] took 0 ms sandboxPid=21, flavor=unsandboxed, command=undefined, entryPoint=(default), docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:59.807 - e[34mdebuge[39m: Sandbox pyCall[get_table_stats] took 1 ms sandboxPid=21, flavor=unsandboxed, command=undefined, entryPoint=(default), docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:59.808 - e[32minfoe[39m: Loading complete, table statistics retrieved... access=owners, userId=5, email=ireche@example.com, age=0, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1, docId=cmPEpwBuq4RWL9jwCuN4tx, num_user_tables=1, _grist_Tables_rows=1, _grist_Tables_bytes=163, _grist_Tables_column_rows=4, _grist_Tables_column_bytes=640, _grist_ACLMemberships_rows=0, _grist_ACLMemberships_bytes=45, _grist_ACLPrincipals_rows=4, _grist_ACLPrincipals_bytes=270, _grist_ACLResources_rows=1, _grist_ACLResources_bytes=62, _grist_ACLRules_rows=1, _grist_ACLRules_bytes=261, _grist_Attachments_rows=0, _grist_Attachments_bytes=171, _grist_DocInfo_rows=1, _grist_DocInfo_bytes=218, _grist_External_database_rows=0, _grist_External_database_bytes=112, _grist_External_table_rows=0, _grist_External_table_bytes=72, _grist_Filters_rows=0, _grist_Filters_bytes=70, _grist_Imports_rows=0, _grist_Imports_bytes=219, _grist_Pages_rows=1, _grist_Pages_bytes=89, _grist_REPL_Hist_rows=0, _grist_REPL_Hist_bytes=67, _grist_TabBar_rows=1, _grist_TabBar_bytes=62, _grist_TabItems_rows=0, _grist_TabItems_bytes=49, _grist_TableViews_rows=0, _grist_TableViews_bytes=49, _grist_Triggers_rows=0, _grist_Triggers_bytes=92, _grist_Validations_rows=0, _grist_Validations_bytes=63, _grist_Views_rows=1, _grist_Views_bytes=96, _grist_Views_section_rows=2, _grist_Views_section_bytes=516, _grist_Views_section_field_rows=6, _grist_Views_section_field_bytes=452, user_rows=0, user_columns=4, user_bytes=67, user_cells=0, num_on_demand_tables=0
2022-08-04 12:13:59.809 - e[34mdebuge[39m: Sandbox pyCall[initialize] took 1 ms sandboxPid=21, flavor=unsandboxed, command=undefined, entryPoint=(default), docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:59.810 - e[34mdebuge[39m: ActiveDoc _applyUserActions(null, [['Calculate']]) access=owners, docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:59.823 - e[34mdebuge[39m: Sandbox pyCall[apply_user_actions] took 12 ms sandboxPid=21, flavor=unsandboxed, command=undefined, entryPoint=(default), docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:59.840 - e[34mdebuge[39m: Sandbox memory memory=48984064, sandboxPid=21, flavor=unsandboxed, command=undefined, entryPoint=(default), docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:59.841 - e[34mdebuge[39m: Sharing _doApplyUserActions access=owners, docId=cmPEpwBuq4RWL9jwCuN4tx, actionNum=0, linkId=0, otherId=0, numDocActions=0, numRows=0, author=grist
2022-08-04 12:13:59.843 - e[32minfoe[39m: Sandbox row count access=owners, docId=cmPEpwBuq4RWL9jwCuN4tx, rowCount=0
2022-08-04 12:13:59.845 - e[34mdebuge[39m: ActiveDoc _applyUserActions returning {actionNum: 0, retValues: [null], isModification: false} access=owners, docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:13:59.846 - e[34mdebuge[39m: ActiveDoc loaded in 1366 ms, InactivityTimer set to 6830 ms access=owners, userId=5, email=ireche@example.com, age=0, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1, docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:14:03.706 - e[32minfoe[39m: Client onMessage '{"reqId":2,"method":"closeDoc","args":[0]}' email=ireche@example.com, userId=5, age=0, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1
2022-08-04 12:14:03.707 - e[34mdebuge[39m: activeDocMethod access=owners, userId=5, email=ireche@example.com, age=0, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1, docId=cmPEpwBuq4RWL9jwCuN4tx, docMethod=closeDoc
2022-08-04 12:14:03.707 - e[34mdebuge[39m: DocClients removeClient 7878f899a0381381 access=owners, userId=5, email=ireche@example.com, age=0, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1, docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:14:03.708 - e[34mdebuge[39m: DocClients now 0 clients access=owners, userId=5, email=ireche@example.com, age=0, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1, docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:14:03.708 - e[32minfoe[39m: ActiveDoc will self-close in 6830 ms access=owners, userId=5, email=ireche@example.com, age=0, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1, docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:14:03.719 - e[32minfoe[39m: Client websocket closed; will discard client in 300 sec email=ireche@example.com, userId=5, age=0, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1
2022-08-04 12:14:03.821 localhost:8484 GET /logout 302 61.640 ms - 2262
^C2022-08-04 12:14:09.015 - e[32minfoe[39m: Server grist[9] got signal SIGINT; cleaning up (3 handlers)
2022-08-04 12:14:09.017 - e[32minfoe[39m: UploadSet: cleaning up all 0 uploads in set
2022-08-04 12:14:09.019 - e[34mdebuge[39m: Sandbox shutdown starting sandboxPid=21, flavor=unsandboxed, command=undefined, entryPoint=(default), docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:14:09.022 - e[34mdebuge[39m: ActiveDoc shutdown starting access=owners, docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:14:09.030 - e[34mdebuge[39m: DocPluginManager.shutdown cleaning up 1 plugins
2022-08-04 12:14:09.031 - e[34mdebuge[39m: Sandbox shutdown starting sandboxPid=21, flavor=unsandboxed, command=undefined, entryPoint=(default), docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:14:09.031 - e[34mdebuge[39m: DocPluginManager.shutdown removing tmpDir /tmp/grist-tmp-90ZHcbM2tR3aS
2022-08-04 12:14:09.034 - e[34mdebuge[39m: DocStorage shutdown success
2022-08-04 12:14:09.039 - e[34mdebuge[39m: ActiveDoc shutdown complete access=owners, docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:14:09.066 - e[32minfoe[39m: Client client gone docsClosed=0, email=ireche@example.com, userId=5, age=0, org=example, altSessionId=tbLm3njx6rcoC8g7WdrEQ7, clientId=7878f899a0381381, counter=1
2022-08-04 12:14:09.066 - e[32minfoe[39m: FlexServer shutdown is complete
2022-08-04 12:14:09.148 - e[34mdebuge[39m: Sandbox exited with code 0 signal null sandboxPid=21, flavor=unsandboxed, command=undefined, entryPoint=(default), docId=cmPEpwBuq4RWL9jwCuN4tx
2022-08-04 12:14:09.149 - e[32minfoe[39m: Server grist[9] exiting on SIGINT
