BUG - Multiple reference in a Form
It seems there is a malfunctioning feature.
I have a multiple reference column in my table. It is pointing to my Product table which has 200 lines more or less. When looking at my form and trying to select my products, it only displays the first 20ish items. I have no possibility to show all of them to the user and therefor the user cannot select many of them. And it seems not possible to display this field as a dropdown list.
To me, this is a bug.
On a side note, I would also love to force this form field to select only one product event though my table column is a multiple reference. But that is an additional feature.
Could you please give me a hand on this? Any way to find an alternative solution?
Same issue here and I do not have an easy alternative solution…
Seems to be relateed to this issue : In Forms, Reference multiple and Choice multiple are limited to 30 entries · Issue #1933 · gristlabs/grist-core · GitHub
