Bug: Toggle Column in Linking Widget not triggering Default Value
Sample: https://docs.getgrist.com/aV7JYYTxwJxg/Toggle-In-Linking-Table/p/2
In Liking widget, if I type something in Note column, it will trigger a default value 2 on ID column from MASTER Table .
But if I clicked on Completed Toggle Button, default value will not be triggered.
Thanks for reporting this! It is indeed a bug. The fix is coming.
