I’m having a weird problem. On one of my older Grist documents, I have start/end data in a table that’s also shown in a calendar. My problem is that the calendar data appears shifted by an hour, as in this screen shot:
Is this on self-hosted instance? Have you tried using latest version of this calendar widget? You can use this URL Calendar Widget to create a Custom Widget. It is the same code we have bundled with latest Grist version.
Oddly, this seems to have “fixed itself” with the recent daylight savings change here in the US. How old is the Python interpreter bundled with grist (and, by connection, the zoneinfo data included with it)?
Thanks for the feedback, I’ll take look into this daylight time change issue.
Calendar widget is purely written in JS (and it tries heavily to adjust the dates).
