Hi! Thanks for a good Calendar widget. Do you have plans to enable export in iCal format? As a hyperlink which I can add to Calendar app (on computer, on iPhone, on Android too).
Hi Mikhail!
This is a feature that definitely is on our radar and that we’d like to implement in the future. Unfortunately, I can’t provide a timeline as to when it will be ready, but we’ll certainly announce it as soon as it’s available.
In the meantime, you may be able to use an integration to create events in Google Calendar when a new record is created in your table in Grist.
