Hello !
A picture will explain better what I’m trying to have (not sure to be able to explain it correctly in English)
I have three tables with links
Constat → Cause
Constat → Actions
And I’d like to add Actions linked to Cause with corresponding choices.
The screenshot should be clearer :
piblic url : Untitled document - Grist
Note: I’ve tried to list the causes in the constat and then have a reference link to this field (Constat.L_Cause) but it does not work and still suggest all the cause in the table …
I’m sure you already spoke about it , but cannot find the way to get it (you can send me the link if it’s better for you).
Many thanks
