Hello, I have a formula that calculates the % cost of a groups time for a project in a Projects table. There is one other group that has a different rate. Right now my rate amount is just typed into the formula. I’d like to make it intelligent so that when rates change I can update the Rate table I made which has two columns: the Role and the Rate. Then, in the same row of Projects, I would know the cost of group1 and group2 which have different rates for other calculations.
So, how to change this formula to reference the particular rate? BTW - the 175 is the rate.
ROUNDDOWN((($budget*0.3)/175.0),0)
Thank you
