Collapsible grouped view based on column values (custom widget)
A custom widget to visually group records with fold/unfold accordion-style — similar to Notion or Airtable grouped views.
Live demo: Test folding groups - Grist
Source: grist-widget-grouped-view
Features:
  • Group by any column
  • Fold / unfold each group — or all at once
  • Sort groups alphabetically or by record count
  • Per-group color picker (persisted via grist.setOption())
  • Configurable boolean display (✓/✗, Oui/Non, badge…) — shown only when a boolean column is present
  • Vertical scroll per group with adjustable max height
  • WCAG 2.1 AA accessibility — keyboard navigation, ARIA, semantic HTML
To use it, add a Custom Widget view, point it to:
https://maximelacoste.github.io/grist-widget-grouped-view/widget_groupes.html
then select Read table access.
Overview :
Config panel :
Wow!! I love it! :heart_eyes: Thank you for sharing.
You can thank Claude AI too. :smiling_face:
Looks really nice, Maxime. Thank you for your work. I see some use cases in the future for us.
Would it be possible to support english?
Thanks. Most (a huge most) part of the work was made by Claude AI. The code is open, don’t hesitate to adapt it to your needs.:dove:
That is something I´ve been thinking about. The french community is very productive and has developed some nice looking widgets across the board. Unfortunately, they´re mostly not localized.
I could try to translate some of them via GitLocalize (which I have never done before). But how would that work for this widget specifically? Does it recognize my region settings in Grist?
Apparently this was already a question on GitHub; Add a how-to translate documentation · Issue #394 · gristlabs/grist-help · GitHub
Claude wants to reassure you ^^
"Good news: the widget can detect the browser language automatically via navigator.language,
without needing any Grist setting. I already use this approach in another widget
(radar chart).
For this grouped view widget, I’ll add EN/FR detection in the next version —
all UI strings (toolbar labels, settings panel, boolean formats, empty state messages)
will switch automatically based on the browser locale.
GitLocalize is a great idea for larger projects, but for a single-file widget like this one,
a simple const i18n = { fr: {...}, en: {...} } object with navigator.language.startsWith('fr')
is enough and keeps everything self-contained.
I’ll update the GitHub repo shortly. If you’d like to contribute translations for other languages
(ES, DE…), a PR with an extra key in the i18n object would be very welcome!"
Thanks for your input, it was very helpful. I implemented it, everything was fine, until today, it just isn’t working. Any ideas?
It should be fixed now.
