I am trying to have a lookup where one of the conditions is the column name. How do I set that up?
I have one table where all my inventory movement is being recorded (Stock Tracker). I am trying to set up another table (Balances) which will calculate balances of each inventory item at each location. So I want to plug in the location (column header) in the lookup formula. It works when hardcoded, but ideally I want it to be a formula if possible.
https://mayanklhila.getgrist.com/oi2YyHdb7o1E/Untitled-document
Thank you for the help!
Cheers,
M
There isn’t a supported way to get the ID of the current column, but there is a hacky way that happens to work today:
table.table._engine._current_node.col_id
The downside is that it peeks into the internals of the data engine, so there is no guarantee it will continue working in future versions of the code.
Hello @Dmitry_Sagalovskiy ,
Is there a formula to get from a table T all columns names ?
By reaching into the internals, yes, you can get that list too:
list(table.table.all_columns)
(or replace table with the name of a particular other table).
As with the “current column” suggestion, the downside is that this is not public interface and there is no guarantee it will continue working in future versions.
