Conidtional style for date
Is there a way to have conditional style with date type ?
Is it on a roadmap or should I add one colum with calculation for each date to check ?
Conditional formatting had a bug for date columns that was fixed recently, and that fix was only just released. If you’re self hosting, pull the latest docker image or git commits. For getgrist.com, try a hard refresh.
Confirm it is working on cloud.
I removed container and image on my local system
then
docker pull gristlabs/grist
docker run -p 8484:8484 -v $PWD/persist:/persist -it gristlabs/grist
I tried changing the persist mount point persitant
I tried new container with importing the file from cloud version
=> No change
Apparently the latest tag is updated daily but not immediately after every commit. Try:
docker pull gristlabs/grist:v0.7.7
