Copy To Clipboard failed
Hi everybody.
I was trying a custom widget for “Copy To Clipboard”.
The sample here “execCommand(‘copy’)” was already deprecated.
So I decided to use “clipboard.writeText”.
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8">
    <title>Copy To Clipboard</title>
    <script src="https://cdn.tailwindcss.com/"></script>
   <script src="https://cdn.jsdelivr.net/npm/alpinejs@3.x.x/dist/cdn.min.js"></script>
  </head>
  <body>
    <div class="content" x-data="{
      btnMes: 'Copy Text',
	    tex: '',
	    showErrMes: false,
	    async copyToClipboard() { await navigator.clipboard.writeText(this.tex); console.log('Copied to clipboard!'); } ,
      <button id="copy" x-text="btnMes" class="bg-green-900 hover:bg-red-800 text-white rounded px-4 py-2"   @click="copyToClipboard(), btnMes = 'Copied'"></button>
      <textarea id="textArea" class="bg-yellow-700 hover:bg-red-800 text-white rounded px-4 py-2" x-model="tex"></textarea>
      <div id="error" x-show='showErrMes' class="bg-amber-200 w-1/12 " >Select a column to copy using the Creator Panel.</div>
    </div>
  </body>
</html>
This program works on its own. However, if you install it as a custom widget, It makes error.
Uncaught (in promise) DOMException: Failed to execute 'writeText' on 'Clipboard': The Clipboard API has been blocked because of a permissions policy applied to the current document.
I would like to know if this error can be avoided.
Thanks in advance.
Hi @naoya.takahashi.
I suspect we need to add some attributes to the custom widget iframes on our end to allow clipboard read and write access. The cross-origin nature of custom widgets may complicate things, but hopefully it’s a simple fix. I’ve filed an issue in our internal backlog to investigate further.
George
Hi George,
I’m also trying to achieve something similar.
Any news on being able to fix this?
Kind regards,
Alexandre
Hi @Alexandre_de_Joncair.
We’ll get on adding clipboard-write access for the next release. The old API (execCommand(‘copy’)) is deprecated, but still appears to work for me (at least on Chrome/Firefox on macOS), so you can try using that as a workaround for now.
George
