Corporate / Branding / Test colors (self-hosted)
I run a few startups. I plan to run multiple self-hosted instances (in docker).
I’d like to make my teammates in certain startup so instead of see all grist “greenish” to see it hued to the corporate colors.
Additionally, as I’m new to Grist, I’ll run a “test server” to make all the “dirty things” before setting them in production. I’d like to also color this instance in yellow or red so I know I’m in “test data” similar to Stripe when you change to “test data”, that you visually see it.
Is there any ENV_VAR to configure the master hue of the instance so buttons and other CSS are colored accordingly instead of “all instances equal”?
It isn’t very convenient, but if you set APP_STATIC_INCLUDE_CUSTOM_CSS to true Grist will load any custom.css file you provide.
There are some notes on styling here:
