Hello, I want to get currency rates value in my table. I make table KURS EURO:
I ask AI Assistant but don’t know how to implement that code:
Please help me to make currency rates in columns KUPNO (means buy), SPRZEDAŻ (means sell) and SREDNI (means average exchange rate) with API: http://api.nbp.pl/api/ to get exchange rates Euro to Polish Zloty.
To fetch currency exchange rates from the NBP API and create columns for buy (KUPNO), sell (SPRZEDAŻ), and average (SREDNI) exchange rates, you can define a function called fetch_currency_rates that takes a date as input and returns a dictionary containing the exchange rates. Then, you can use this function to create the new columns in your data table.
Here's the code for the fetch_currency_rates function:
import requests
def fetch_currency_rates(date):
# Format the date in the required format for the API
formatted_date = date.strftime('%Y-%m-%d')
# Make a request to the API to fetch the exchange rates
url = f'http://api.nbp.pl/api/exchangerates/rates/A/EUR/{formatted_date}/'
response = requests.get(url)
data = response.json()
# Extract the exchange rates
rates = data['rates'][0]
buy_rate = rates['bid']
sell_rate = rates['ask']
average_rate = rates['mid']
return {
'KUPNO': buy_rate,
'SPRZEDAŻ': sell_rate,
'SREDNI': average_rate
I try to add that in formula field but get error:
Can somebody help me with that?
Regards.
