Hi there,
I think it would be super-helpful if we could have more field flavours, and/or custom fields… For instance, we have a “date” field type and a “datetime”, but we lack a “time-only” field… and even if I choose a datetime field with a custom format and I leave the date format blank, the widget will still display both the calendar and the time picker. Or, sometimes I could use a 3-way toggle field type. Or, a limited integer field type, rendered as a slider, perhaps.
Another use case: a “text” field in a table at the moment can be rendered either with a textbox or a hyperlink display, but there’s no way to store-and-display formatted text (say, html or markdown) directly (without a dedicated widget, I mean).
Indeed, we do have custom widgets… but they are rather bulky and you have to add them in a page, separately from (say) the card widget displaying all the other fields of your record. Plus, a custom widget can only be linked to a single field, afaik.
Say you have 3 “text” fields in a table, all of them have to store/display markdown-formatted text. If not a proper markdown-flavored text field type, it would be great to have a multi-field-tracking markdown custom widget… This way, you could make a page with a card widget for all the fields, and a single “multi-purpose” markdown custom widget, so that when you clic on a field on your card, the markdown widget displays/edits the formatted text stored in that field, if applicable. It would still be a considerable waste of screen space, but I could work with something like this.
But I don’t think this is possible with the current widget api… or is it!?
