Custom number format
Hi there!
I wanted to ask about adding a custom number format.
Right now we have the option between preselected currencies, comma, percentage and exponential. I’d love to see a “custom” option where you can add your own string to append (or prepend) to every numeric value.
This would just help in cleaning up how it looks when recording data that is not financial, for example… Data usage. It is of course possible to just record it as a number, and not append a string to it, but it is much easier to read this way.
The column can look like this, but still be read from as a numeric value rather than adding it as text.
Hi there!
I love this idea of adding a unit/label on to a number. Great idea for a future improvement.
If you’re looking to improve this from a data-entry perspective, you could make the Data Usage column a trigger formula column that automatically adds the unit onto an entered value, using the formula value + " MB" and apply on changes to the current column, Data Usage. Then, you could type 25 and the unit would automatically be added when you hit enter.
The column would have to be a Text column since it is a mix of alpha-numeric characters but hopefully would help from a data entry perspective.
I will share your idea to add a customizable label/unit option to numeric type columns with the team!
Hi, any update on this? I just came across this need as well.
I would also like to mention that it’s probably not about adding prefixes/suffixes, but more generally providing the number format. The way Excel does it is pretty good, which is you can do something like “My number: #,###.##” and the value would show up like “My number: 5,342.49”.
The Trigger formula solution above is good for display purposes, but then the column is no longer a numeric type, so you can’t aggregate on it (i.e., in the example above to be able to SUM up the Data Usage).
Not to hijack this topic, but can I just drop in to say: Grist could really profit from separating cell input and cell output generally. Ideally, we could set an (optional) “display formula” per column. That way, you could use a trigger formula to compute the actual value and a different formula to change how it appears.
From what I understand of Grist’s internals, this wouldn’t require an awful lot of changes, either. The data engine would just have to call the “display formula” whenever it recomputes the cell, and store the resulting “visual data” somewhere. And the display widgets for table view and others would have to be adjusted accordingly, so that they show the “visual data” (if present) rather than actual data.
I’d love to hear what people think of this.
I am facing the same problem, I want my cell values in a Weight column to be in grams (g).
@natalie-grist I tried your solution but it doesn’t work:
Thanks!
EDIT: It only adds the g suffix after editing a new cell which is doable by hand by editing the cell. This is not really what we want since we can edit the suffix too. The solution provided by @TomNit seems promising.
Slightly confused that this is still not a feature. It feels like a relatively minor, but basic requirement if you want to get customers that are coming from Excel and similar.
Does anybody know if there is anything on the horizon?
I can only say I share that sentiment entirely. In fact, I’m a bit worried these days. Grist was off to an absolutely phenomenal start, but IMHO it needs to pick up a lot more of actual spreadsheet functionality and do it fast if it wants to advertise itself as a real Excel alternative. I hope the dev team realise this.
If it were my database, I’d likely put the units-of-measure in their own column, so that the column that’s supposed to contain a number can really be a number, and be used as a number.
Hi there!
+1 for this feature!
I completely agree that custom number formats with prefix/suffix would be a great addition to Grist.
Being able to display units like “m²”, “kg”, “hours”, or any custom unit directly in numeric columns would make the interface much more user-friendly and professional-looking. Right now, we have to either:
  • Create separate formula columns (which clutters the table)
  • Put the unit in the column name (which is less intuitive when viewing data)
  • Live without units (which makes the data harder to understand at a glance)
The workaround of concatenating values with text strings (like str($Surface) + " m²") creates multiple major problems:
  • You can’t perform calculations on text columns - you need to maintain two separate columns (one numeric for calculations, one text for display)
  • Sorting and filtering become problematic - text sorting would put “10 m²” before “5 m²” (alphabetical order instead of numerical order)
  • This defeats the purpose of having a clean, streamlined interface
For non-financial data (measurements, quantities, rates, etc.), having this simple formatting option would significantly improve readability and the overall user experience. It’s a small feature that would make a big difference in how clean and professional our documents look.
Bonus feature idea (going further):
While we’re on the topic, another really powerful enhancement would be to have preconfigured physical quantities with automatic unit conversion. For example:
  • If a column is set to display as “kg” and I type “15g”, it would automatically convert and store 0.015 kg
  • If I type just “15” (without a unit), it would use the default unit (kg in this case)
  • If I change the display unit of the column from “kg” to “g”, all values would automatically convert in the display
For formulas, there would need to be two approaches:
  1. Either reference the displayed value (so formulas would need adjustment if you change the display unit)
  2. Or better yet, allow retrieving values in a specific unit (e.g., $Weight.as_kg() to always get kilograms regardless of display unit) - this way formulas wouldn’t break when changing the column’s display unit
I realize this would be taking things quite far, and just having the ability to add a simple prefix/suffix would already be a great starting point! But it’s worth mentioning for the future roadmap. :blush:
Would love to see this implemented! :folded_hands:
I would be very interested by this feature too !
Some related github issue. I don’t know where they should be upvoted yet.
Units for numeric columns #1836
The workaround mentioned above:
  • add a new column with formatted string:
  • keep the original numeric column and use it for computation in formula
Some samples:
# return a string, no more suitable for arithmetic computation
= f"{$my_surface} m²"
More complex formula for computer storage
def format_size(size_bytes, suffix='B'):
    for unit in ['', 'Ki', 'Mi', 'Gi', 'Ti', 'Pi', 'Ei', 'Zi']:
        if size_bytes < 1024.0:
            return f"{size_bytes:3.1f} {unit}{suffix}"
        size_bytes /= 1024.0
    return f"{size_bytes:3.1f} Yi{suffix}"
# Example usage
return format_size($value)
