I have a little problem, If I select a different customer, the report does not update. . I could reload the frame, that the right content get displayed
I put all the java script in the same file to better debug the problem. I guest that it has to do with the life of the data variable. but I am not sure…
how can i force a reload of the custom widget content?
Hi @JuanJosePablos, to get a notification when the selected row changes, you could use grist.onRecord (note the singular onRecord versus the plural onRecords)
I see one example of it being used along with Vue.js here:
