I would really
for tables in Access Rules to be sorted alphabetically instead of how it currently is, which is the order of creation. Sometimes you need to make adjustments that affect multiple tables and having to search for related tables can really mess with your concentration about what you are seeking to adjust, especially when the number of tables and rules start to increase.
Additionally, it would be great (but not essential) if tables could also be
- filtered so you only see the ones you need for specific rule modifications.
- sorted by last modified date
Thanks, David.
