If you are into bookkeeping, and want to use Grist for your double entry accounting, and easily create Income Statements easily based on Cash or Accrual Accounting, as well as Balance Sheets, look no further!
It would be interesting to have full access to the document
I set it to template mode, you should have full access to create your own copy as a template now.
Limited access. When you try to copy it, you get the message that you don’t have sufficient permissions.
Try again, I just modified the permissions.
Sorry, try one more time. There was another setting we forgot and it should work now.
Now yes, thank you very much
