Hi there,
I am currently diving into grist being really awesome.
Within my data there is a lot of repetition (like meta fields… Created. Modified. User. Etc)
Checks and references are repeatedly used.
Is there a possibility to edit the code?
Otherwise maybe custom column templates might help with that.
During the writing it might be possibility to prepare template tables and duplicate them. ![]()
Defining documents as code would be awesome, if not already possible and I simpy overlooked it.
Thank you!
Gandalf
