I have a table that I use to filter records in my main data table.
Each field is a Toggle CheckBox so I can check which fields I want included in my results tables.
The image below is an example of what happens when I check or un-check the filed. Instead of simply clearing the check, it will switch to the Text style and the CheckBox doesn’t clear.
A bug in Grist, or did I do something wrong?
