May it be possible (I guess through an action button) to export the current record in a table in a text file ?
(I would extract Name/Surname/Email/… and generate an appropriately formatted vCard)
Any ideas are welcome,
Thanks!
Thanks!
Replying to myself… maybe the right way is to adapt the existing “Inspect Record” custom widet…
There is a VCard field in this sample:
https://docs.getgrist.com/7CJcCLNS8v4T/QR
Exporting the data of this field thanks to a custom widget wouldn’t be difficult.
Thanks for the suggestion! I used the vCard as in your example and wrote a simple custom widget adapting the “copy to clipboard one”.
