When managing documents with a large number of users (100+), finding a specific person is painful because the user list is not sorted alphabetically. This affects two critical places:
The sharing/access panel (to update permissions)
The “See As” feature (to verify that ACL rules are correctly applied for a given user)
With 100+ users — and I have some documents with 500+ — my brain is
every time I need to go there. It feels like searching for a needle in a haystack.
Could you add alphabetical sorting (A-Z) by name or email in:
The sharing panel (Manage Access)
The “See As” dropdown
The ••• shortcut on the Access Rules menu link
This seems like a small change with a big quality-of-life impact. Would this be something others could benefit from, and feasible to implement?
