Fetch current selected row from a custom widget
Hello😄 ,
Is there a way yo fetch the selected row of a table in a custom widget ?
Even if it’s not connected directly via the “SELECT BY”.
Hi Sao,
Currently, it is not possible but we are thinking about a way to extend the ‘SELECT BY’ feature to allow such a use case (selecting by more than one table).
Hello @jarek, any news on that since 2022? I would love to use “Select by” on a table which is based on what the user does in a custom widget
