Hey
I didn’t get how to use the filter by range for dates column ?
And can we filter for example with the expression NOW to make the list always showing the today list.
Or we should add a formula in a new column ?
Hi Sao,
(Grist dev here…)
- In the current version, range filtering a Date column only support typing in the date.
- We are actively working at releasing features that’ll make it better, which includes a datepicker and a relative range picker that let you specify relative range such as
Last 3 months,Next 4 yearsor alsoThis week, stay tuned … - Keep in mind that while typing in the date, the filter guesses the date based on the date format of the column. For instance if date format was
YY-MM-DDyou could type in2022-07-02which is often shorter that typing the full date.
Best,
