Filter records by value used in ReferenceList when using API
I want to make an API call such that it returns all records from my table which contain certain value in the column with the ReferenceList type. Is it possible?
You can do anything you like with the /sql endpoint. If you’ve tried with the ?filter option of /records and it isn’t working for you, then I think that will be the best option. Read the data with /sql with a plain SELECT * FROM YourTable, and see how the ReferenceList looks in SQL results, then create an appropriate WHERE clause to get just the rows you want.
It looks like
"type": "Buffer",
          "data": [
            91,
            2,
            0,
            0,
            0,
            117,
            1,
            0,
            0,
            0,
            76,
            105,
            5,
            0,
            0,
            0
How should I convert it to reference ids?
I think that is a “display” helper column which is a little weirdly encoded. You could make another column, maybe hidden, that reads out what you want in a friendlier format. I put an example here:
RefListSql - Grist
and then a query could be:
https://docs.getgrist.com/api/docs/7UNJ7qiJ5DJ8/sql?q=SELECT+*+FROM+Orders+WHERE+EXISTS+(SELECT+1+FROM+json_each(Readout)+WHERE+value+%3D+‘Cat’)
(If you use the POST variant of the /sql endpoint you can pass in the query and parameters in a more sensible way)
There’s doubtless a cleaner way to do it.
