Filtering Reference choices in dropdown in Form view
Hello. I was able to do the “Filtering Reference choices in dropdown” instruction to filter the dropdown list in the Table view. But I can’t customize it in the Form view. Please help me to do it.
Forms still have a LOT of shortcomings and missing features. You don´t have formulas working on Forms for example. And the filtered references is dependent on a formula. So I guess it’s another thing that doesn´t work with Form widget yet.
I also expected the form to use this settings ( or even have its own setting ).
Unfortunately it does not have it yet.
That’s one of the reasons why I use telegram bots instead of forms to allow people to add data into the document.
We really need the good friend implementation.
