Hi there!
I created a quick example using my Parish’s data. You can view it at the link below:
https://public.getgrist.com/gvUWqfmAHB9Z/Community-637/p/2
Two things to note - make sure your Date column is the Date column type and the numbers columns are all numeric. Otherwise, you may get an error on the formula column.
In the document, I have the following formula in the comparison column.
prior = DATEADD($Lab_Collection_Date, days=-5)
cases = Covid_Cases.lookupOne(Lab_Collection_Date=prior).Daily_Positive_Test_Count
int(cases)/$Hospitalizations
First, we need to find the date that was 5 days ago. So, we take the date in the Lab Collection Date column then subtract 5 days.
Next, we need to find the number of positive cases on that day. Format here is TABLE_NAME.lookupOne(COLUMN_A=prior).COLUMN_B
where Column A is the collection date column and column B is your case count column.
Last, we compare the two! I have int() added so you can format this formula column as a numeric column. this allows you to format your result as a percentage and/or adjust the number of decimals you wish to show using the column configuration panel on the right hand side of your table.
Let me know if you have any questions!
