Get base64 encoding of an attachment
Continuing the discussion from Attachement url for html_widget:
would it be possible to get a base64 encoding of an attachement? This would allow easy inclusion of images within custom widgets, especially html rendering.
Many thanks again for all the great work!
True, this is hard to use in the renderhtml (HTML Viewer) widget. It is possible already with some effort, and I put an example here:
https://public.getgrist.com/mSxCywdTTSJa/Attachments-in-HTML-Viewer/p/1#a1.s1.r1.c2
  1. Firstly, since you need to run JS, there is a hidden way to allow that in the renderhtml widget. Use the widget by choosing Custom URL option, and use the URL of https://gristlabs.github.io/grist-widget/renderhtml?tags=script. (The tags=script option allows <script> tags in the HTML to be rendered.)
  2. Second is you need a fairly sophisticated formula that combines Python and Javascript. The one in the example is this:
    setImageSrcScript = """
    <script>
      grist.docApi.getAccessToken({readOnly: true})
      .then(tokenInfo => {
        for (let img of document.querySelectorAll('img')) {
          if (img.dataset.att) {
            img.src = `${tokenInfo.baseUrl}/attachments/${img.dataset.att}/download?auth=${tokenInfo.token}`;
    </script>
    return """
    <div style="padding: 24px; background-color: #F4F0FF">
    {setImageSrcScript}
    <h1>{Company}</h1>
    <p>Hello world!
    {att}
    </div>
    """.format(
      setImageSrcScript=setImageSrcScript,
      Company=$Company,
      att='\n'.join('<p><img data-att="{}" width="100%">'.format(att.id) for att in $Attachments)
The setImageSrcScript part is meant to be reusable with no changes in other such image-rendering formulas; it goes through all <img> tags with data-att attribute equal to the id of an attachment, and adds a suitable src tag for those.
As for a better approach, the problem with using base64 encoding in a formula to compute HTML that includes the full body of attachments is that it can produce very large formula results. Grist doesn’t handle those very efficiently. For a large table, it could quickly become a problem. I think a more promising approach would be an improvement to the HTML Viewer widget that automatically does something similar to what’s done by the setImageSrcScript above.
