Hi guys!
Have you ever needed to choose different reference column names for formula?
I will try to desribe what I want to achieve.
I have table for products and prices, but I need more than just 1 price for each product and then I have a choice column which could switch what column to choose for the formula. Each price column depends on which date it was published, so I don´t want to have all prizes actual, because I want to compare old prize and new one.
formula is something like: products.price * number I need my formula to dynamicaly change “.price” to “.price5” or whatever I choose from choice column.
Hi ! I’m trying to do pretty much the same thing but the difference is that prices are stored in a separate table…
To be a little more specific :
i have a MALTS table which contains one type of malt per line, and a PRICE column for each year’s price
a recipe table which contains :
15 columns : $NOM_MALT_1 to $NOM_MALT_15 which refer to the MALTS table
15 columns : $LOT_MALT_1 to $LOT_MALT_15 which si manually filled with the serial number, which contains the year of production
15 columns $MALT WEIGHT_1 to $MALT_WEIGHT_15
a total malt price which should return the result of the following formula : $NOM_MALT_1.PRICE*$MALT WEIGHT_1 + $NOM_MALT_2.PRICE*$MALT WEIGHT_2 etc.
I’d like the price to be selected dynamically according to each $LOT_MALT_x… I know i’m getting close but i can’t figure out how to properly do it. Here is a fragment of my total malt price formula (it’s kinda brute force with 15 if loops but i’ll optimize someday) :
prix=0
année=0
#if column $MASSE_MALT_1 is not empty
if $MASSE_MALT_1:
#extract the year from the corresponding serial number
year=MID($LOT_MALT_1, 3, 2)
#calculate the MALT_1 subtotal price and add it to the "prix" variable
prix+=$MASSE_MALT_1*getattr(rec, "$NOM_MALT_1.PRIX_AU_KILO_"+année)
#repeat the above for each $MASSE_MALT_x :
if $MASSE_MALT_2:
return prix
Can you create a shareable version of your document that I could take a look at?
It’s not totally clear to me how the rows of the MALTS table line up with the recipe table. And I’m a bit confused about what values should be totaled in the final price column of the recipe table.
Not sure how to do that, what i did here was click on the share icon on the top right grist UI, manage users, make public and pasted the given link… Is there an other way i don’t know ?
I was meaning to reply, but I dropped the ball.
Thanks for the gentle nudge.
What you wrote two weeks ago should have worked. Rather than messing around with public access on what seems to be your businesses’ server, I suggest you do this instead:
share icon on the top right grist UI > Download…
download a copy, without history (2nd choice) will be lighter
at the top left, green button [Add New] > Import Document
import your .grist file.
Once imported, start overt with the sharing process you used last time, but from this Grist cloud hosted copy.
Let me know how it goes.
m
P.S.: Ça a quelque chose d’absurde de correspondre en anglais avec des “cousins” outre-Atlantique qui parlent la même langue que soi. Mais pour le bien du plus grand nombre (sur ce forum), faut ce qu’il faut.
Only 3 weeks later, i’m back ! Here is the shared version, it is also skinned down to the very lightest to keep only what matters in this particular case.
Anyway thanks for your support !
Oui c’est toujours marrant de parler en anglais entre francophones, c’est pareil sur le forum yunohost où je traine beaucoup sauf que là bas on essaie de faire des posts bilingues pour se simplifier la vie
Sorry about the delay! I didn’t see your previous reply.
Looking at the shared doc, it looks like I can’t make any edits, which means I can’t see the whole formula you’re trying right now and cannot experiment with changes to get it to work. Can you modify the permissions on the shared doc?
You were using prix = getattr(rec, "PRIX_AU_KILO_"+année), but I’m pretty sure you need to use prix = getattr($MALT_1, "PRIX_AU_KILO_"+année).
You were accessing the column "PRIX_AU_KILO_"+année in the current table (using the rec variable, which is a row in the current table).
You need to access the column "PRIX_AU_KILO_"+année in the Malts table, which you can do by using the $MALT_1 column since it’s a reference to a row in the Malts table.
Let me know if this is what you were looking for and if the reasoning makes sense!
