How can I use the current field to style the cell ?
I wanted to avoid "rec.Name " in case the column’s name change.
Hi @Sao.
It should be ok to use rec.Name. When a column is renamed, any mentions of it in formulas will automatically be updated to use the new name.
George
oki thanks,
is it the same with “$Name” ?
Yes, $Name works the same way.
George
