Get reference count by fomula?
제목 없음
I want to fill increment number in Column “count” by the Column “ref” info.
Column “ref” is Reference and I chocie “A” or “B” or “C”
I want when I choice something in the column “ref” (eg “A” or “C”)
then automatically ‘count’ Column add next number
but how? I found each column has unique $id and same reference field share the $id value.
but I don’t know how to use them
This formula should do the trick, as shown here:
table.lookupRecords(
  ref=$ref,
  sort_by="manualSort"
).id.index($id)+1
