I am self hosting Grist on a hosted server using Yunohost. I created a document which is about 6MB on disk (the SQLite database size). I mostly interact via API. I noticed that the first operation I run after a while (say first time during the day or in a few hours) it will often take 5-10 seconds to complete. Subsequent operations after that will take a few hundred milliseconds at most.
Is this expected behavior? Any recommended path to speeding it up? I’m not particularly memory constrained and there isn’t a ton else going on on the server. I tried switching the SQLite mode to WAL but it didn’t solve this issue.
Documents do exhibit a warm-up period when accessed for the first time. This is typically the case when no browser clients currently have the document open, and you try to access the document after a timeout period (~30 seconds), including via an API call. The length of the warm-up period scales with the size and complexity of the document, as tables and rows need to be loaded, formulas calculated, etc.
I don’t believe we have a way to configure this behavior right now. It would be useful to be able to do so (perhaps on a per-document level, as the current behavior exists for good reason – to reclaim unused memory when documents are not in use).
Thanks @georgegevoian! Could you point to roughly in the code where the cleanup / cache expiration happens? Want to see if we can either work around it or possibly submit a PR. Being able to configure it, even globally or at the document level would be super helpful.
