Context
As a teacher, I would like to create my math exercices directly in Grist. There’s already the Markdown widget that allow me to create reports and summaries.
However, what would be awesome would be to be able to write directly interpretable code inside Grist.
Current setup
Using the custom widget, I was able to have the following working code that uses MathJax
Table setup
Having a column content that contains HTML code that will be inserted in the content div element.
HTML
<html>
<head>
<script>
MathJax = {
loader: {load: ["input/asciimath", "output/chtml", "ui/menu"]},
output: {font: "mathjax-newcm"}
</script>
<script defer src="https://cdn.jsdelivr.net/npm/mathjax@4/startup.js">
</script>
</head>
<body>
<div style="font-family: sans-serif; padding: 1em;">
<h2 id="title"></h2>
<div id="content"></div>
</div>
</body>
</html>
JavaScript
grist.ready({ requiredAccess: 'full' });
grist.onRecords(table => {
grist.onRecord(record => {
document.querySelector("#title").innerHTML = record.Titre
document.querySelector("#content").innerHTML = record.content
let currentRecord = null;
grist.onRecord((record, mapping) => {
if (!record) {
return;
currentRecord = record;
el.innerHTML = record.content;
const el = document.querySelector("#content");
el.addEventListener('change', async (e) => {
const elementContent = e.target.value;
const delta = {
fields: {
"content": elementContent
await grist.selectedTable.update(delta);
Problem
- As of now, the widget works, but as I’m modifying the value of
content, the HTML display stops working. I have to reload the web browser page to display it correctly, as if the custom widget wasn’t working when I change the content. A solution would be to have a Markdown-like widget with an Edit button to change the code directly inside the widget and interpret it whenever I quit it - As of now, the page is using the AsciiMath notation, however it would be great to be able to directly write LaTeX code
