Hi !
I recently tried using the “Action button” widget, because I believe I’ll be needing it further on in my project.
But I can’t seem to make it work, I keep getting the same error :
cells should contain an object with keys “button”, “description”, “actions”. Missing keys: “button”, “description”, “actions”
I reduced it to the simplest possible form (opposed to generating the result based on more complex code), and still nothing. I don’t understand what I missed.
I isolated a sample here : GPAO - Grist
If anyone can tell me what I missed, I’ll be very, very grateful, because I’ve been going a bit
Thanks a lot !
