I have been using both the dropdown widget and the multipage dropdown widget, Drop-down Widget. They used to show just the selection, so it could be a smaller one line view, taking up less space. Now, it seems like there was some kind of update making them much taller, forcing vertical scrolling to see the one selection, or you have to keep it big on the page? Is there a setting I’m missing somewhere to change the height so it doesn’t take up so much space?
We found the issue. A fix will be included in an upcoming release.
George
Thanks for the update, glad you found it
